Another minor software update??
Discussion in 'Satellite TV, Sky TV & FreeSat' started by simon194, Apr 24, 2007.
  1. simon194
    simon194
    Nov 29, 2006
    1,806
    63
    +221
    Just got home from shopping and switched on my HD box and it was on 998.
    It seem they have fixed the problem with the HD content in Anytime where it didn't switch to 1920x1080i when the box is set to Automatic.
    The OS and EPG version numbers are still the same.
  2. Neil Watson
    Neil Watson
    Jun 25, 2001
    971
    Bracknell
    +78
    Its a bit of a bodge though as on mine set to Auto it does the following.
    Started on ch101 (i.e SD res)
    Went into anytime
    Selected an SD program - Stayed in SD
    Back into menu - stayed in SD
    Selected HD program - immediately switched to 1080i
    Back into menu - stayed in HD
    Selected the SD program again - ITS STAYS IN HD which isn't what I want since I've opted for auto setting!!!!
    So all they've done is swap the latching from being 576 to being 1080i - Granted its better as at least you now see HD in HD but you'ed think they'ed correct it properly :rotfl:
    Fortunately it does switch back when you exit i.e. backed completely out of Anytime and back to ch101 and it switched to SD again. Previously with anytime sticking on SD it would cause HD planner recordings to stick in Sd too.
