edd666999
Looking to replace the Mrs ageing XPS with a new desktop machine. Shes a photographer, uses a 5DMK4. She currently just does photo editing, All her media is stored on some network storage (raid10) + (Cloud)
Moving forward she wants to be able to edit video, play some esports games. Shes uses the Adobe suite of software for all her work.
I want a true 10bit display 27". I cant seem to find another display that beats the Benq, any suggestions?
I have a 10GBE switch so want to be able to transfer at full speed from the nvme to the ssd cashe on the network storage box, suggestions for a pci card?
I was always under the impression im going to need a quadro or radeon pro for true 10bit support in Photoshop and lightroom but apparently theres some new nvidia drivers (studio drivers) that unlock 10bit. I have a 1050ti in my plex server so going to do some testing before I purchase the GPU. If I have to buy a Pro card it would be a wx5100 I thing, 2nd hand around £240.
My current build idea:
AMD Ryzen 7 2700 3.2 GHz 8-Core Processor Purchased at £100
MSI B450M MORTAR MAX Micro ATX AM4 Motherboard Purchased at £82.48
Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3600 Memory Purchased at £62.50
Thermaltake Core V21 MicroATX Mini Tower Case Purchased at £48.00
Noctua NH-D15 SE-AM4 82.52 CFM CPU Cooler Purchased at £76.50
Corsair HX Platinum 1200 W 80+ Platinum Certified Fully Modular ATX Power Supply Purchased at £149.99
ADATA XPG SX8200 Pro 512gb M.2-2280 NVME Solid State Drive Purchased at £59.57
Gigabyte GC-WB1733D-I PCIe x1 802.11a/b/g/n/ac Wi-Fi Adapter Purchased at £21:59
MSI GeForce RTX 2060 6 GB VENTUS XS OC Video Card Purchased at £278.00
BenQ SW271 27.0" 3840x2160 60 Hz Monitor Current Price £959.99
£878.88 spent.
Need recommendations on a 10GBE card.
*Im aware that psu is massive overkill, ignore that as I've got other plans for the PSU in the future.
As you can see I've already made a start so changes will be limited! I was planning on mirroring the nvme drives, as although she is *supposed to* save everything on the network, shes a user!
I thought swapping the 200mm fan in the case to the noctua will give quieter results?
I was hoping that massive D15 cooler would run almost fan less at times?
Thanks to those who read this far and thanks for any suggestions
£878.88 spent.
