Another HDMI Question....sorry!
Discussion in 'Cables & Switches' started by Mr Yakimoto, Feb 9, 2009.
  1. Mr Yakimoto
    Mr Yakimoto
    Jan 20, 2005
    785
    2
    46
    Kent
    +147
    Do you really need a specific HDMI cable that has "120hz capability" or is this nonsense?
  2. andy1249
    andy1249
    May 7, 2006
    8,606
    +2,654
    Its nonsense , 120hz is a processing technique applied to the signal by your Display electronics "after" it has travelled down the cable to your TV.
    So the cable cant possibly have anything to do with it.
  3. Avi
    Avi
    Dec 30, 2004
    13,963
    +2,064
    Ignore 120hz claims but some source devices can use higher bandwidth i.e. higher colour bit depth etc and this can cause an issue with some cables especially as the length increases.
    If you want to ensure you have a cable that is capable of supporting the full capability of current HDMI then look for a CAT2 certified (at the required length) product. You don't need to spend a lot as there are decent products that start around £10 for short lengths.
    AVI
  4. Member 319784
    Member 319784
    Nov 3, 2008
    1,502
    Malvern
    +240
