Of all times to do this - best summer of sport for years and I've not had this set up done... Ah well, here's hoping it all works out.
Nothing spectacular in terms of innovation - but I thought Groove's idea hardly needed anything added to it. If you read this Groove, thanks for the inspiration (and design) for this.
Still a work in progress, but getting there.
Next stage, after what you can see on these pictures, is to put a primer on the timber, give the wall another couple of coats & also paint the timber frame.
Then it'll be the brackets being added for the centre speaker, the TV and the shelf below the TV / above the speaker.
Should you be wondering - the letter box looking cable tidy will have a shelf covering most of it so you can just see the brushes in the centre of the shelf. It's a floating shelf which can be slid in and out for easier access - and the shelf is for a webcam / PS3 / Wii receivers etc.
I've just bought the 55" Panasonic plasma (the one that got the Reference score on here) and I've, so far, got a B&W CM Centre, and 2 white MT's for my surround. Once the wall is done, and the floor is down I will be going to get a pair of CM9's
The speaker cable for the CM9 will be hidden in a piece of white trunking which runs along the underside of the wall, which you can't see.
I'll continue to post pics as I go.
