Another E30 question
Discussion in 'Blu-ray & DVD Players & Recorders' started by TommyVecetti, Mar 14, 2003.
  1. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
    :cool:
    Happily been using my E30 for about a month now. Just wondered what peoples views were on the picture recording modes 'fine' and 'normal'.
    I'm confused about them.
    I've used both and don't reckon I can notice any difference at all? The manual says use 'normal' when recording noisey pictures (from VHS maybe?). but leave it on 'fine' most of the time. I would have thought that 'normal' mode would be called 'normal' because that is what you'd use 'normally' most of the time. But fine mode is the norm, apparently.
    So does anybody with an E30 have a view on these modes? I'd be greatful for your thoughts, incase I'm missing something.
  2. ferris57
    ferris57
    Jan 18, 2003
    874
    I've been wondering the same thing. Sometimes I find the pq a bit washed out looking, and thought changing this may help, but no luck.
  3. bobbles
    bobbles
    I do not notice much of a difference, I thought it probably would only be an issue for plasma screen owners
  4. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
    Thanks. :cool: I suppose the only way to really find out is to record a really noisey picture, but thats not likely to happen.
  5. malcom
    malcom
    Aug 25, 2001
    526
    +4
    Hi TommyVecetti. I agree the Panny logic in their "Normal" wording is a bit of a puzzle.
    As for the difference between the settings. I have some really rubbishy grainy tapes and for that reason have left it set on "Normal" If it's not my imagination "because I am expecting it" I do detect that my grainy tapes do come out better on the "Normal" settings. However (Normal tapes):D I detect no difference whatever setting I use. Does that sound normal:laugh:
  6. TommyVecetti
    TommyVecetti
    Feb 10, 2003
    1,763
    uk
    +93
    :D
    Yeah it's a mystery. It must work better for archiving VHS.:D
