another dumb newbie question?
Discussion in 'Plasma TVs' started by i am kloot, Sep 21, 2004.
  1. i am kloot
    i am kloot
    hey y'all.....just got my sony kep42m1s set up...connected the dvd with a gold scart and it looks superb...used a normal scart for the sky and it leaves a little to be desired especially when watching footie...the grass looks computer generated and the faces are a little blurry....if i shell out another wedge for a gold scart lead will this solve the problem? dont tittter if there is a better solution, remember i am a technophobe....cheers. :clown:
  2. Blu Ray
    Blu Ray
    Jun 14, 2004
    495
    Chorley, Lancs
    +12
    Decent leads always make a difference. I've always favored Ixos ones myself, but others may differ. Ensure the plug bit is metal for max shielding. There is a cable section in this forum too.
  3. pmccreight
    pmccreight
    Sep 8, 2004
    9
    Belfast
    A good cable will make a diff but football viewing is a major problem on all plasm/lcd. No matter wot you try it will still look pretty rough.
  4. Stallion
    Stallion
    Aug 19, 2004
    22
    Norwich
    Monster cable make some decent cable, have loadsa patents to their technology, all scarts have 100% mylar foil sheild and copper braid on some....may deliver a better picture.
  5. i am kloot
    i am kloot
    got myself a couple of monsters and it seems to have done the trick. :clown: :beer:
