another dpa 32r question
Discussion in 'TAG McLaren Audio Owners' Forum' started by real batman, Jun 15, 2005.
  1. real batman
    real batman
    ... what does the 44.1 hz mean on the readout and does this ever change.. :cool:
  2. liam_b
    liam_b
    Apr 24, 2002
    390
    28
    Wilds of north Leicestershire
    +25
    if look closer you see that it says 44.1KHz and that is the frequncy that the current analog audio input is being sampled at and output on the digital outputs. before you ask - no your analog output is not going via ADC/DAC chain, the DPA32 does full cross conversion, better than any digital recorder I've tried too.
    you can set the sample rate to 32, 44.1 and 96KHz, IIRC, and seperately for each input.
    all this is covered in the user manual.
