Johnny.G
Already using two svs subs in dedicated room but after being converted by Swiftpetes two 18" cylinders have decided to go diy instead of commercially upgrading . Was going to do cylinders but just can't intergrate them into the available space of the room. Example of build can be seen on Hometheatershack site under "Enclosure Volume Calculator".
Fairly accurate shopping list costs below for anybody contemplating something similar.
5 sheets 25mm mdf ..................................................... £146
12 mtrs 14 oz fibre fill wadding ...................................... £36
2 Fi Q18 D2 drivers .................................................... £680
3mtrs 6" soil pipe ....................................................... £32
4 x 60 wood screws .................................................... £12
Wood glue ................................................................. £12
2 recessed speaker binding posts ................................... £16
1 Behringer EP4000 ..................................................... £ 247
2 18" speaker grill covers (if used) ................................. £16
2 6" speaker grill covers for ports (if used) ...................... £10
Primers and paints / coverings ?? ................................... £20
Total in the region of £1227.00.
Will be using existing Antimode.
My Joiner friend and i have done some constructing today, will post up some pics when i remember how to do it !.
