J
jmack
panny/toshiba owners
been messing with the settings again and i have a question on the component imput / picture adjustments you have the option
normal> dynamic>cinema
which can all be set to what ever you prefer ,
my question is if they are all set the same ie. contrast 5 / brighness 5 colour 2 sharpness 1 etc, will they all be the same ?
as in is there any other reason to choose normal over cinema if you can change the picture settings in both to whatever you like?
am i making any sense , does say cinema mode do some thing different to picture than normal would not?
cheers
cheers
