Another conversion underway.
Discussion in 'Home Cinema Building DIY' started by tykent, Apr 10, 2005.
  1. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    Hi All
    I have finally started my garage conversion. I have had some of my equipment sitting idle for almost a year now. New baby and a house to finish has delayed things.
    Anyway, I thought I'd post now as it's always good to get advice as you're going along. It's not going to steam ahead but will hopefully be completed by June.
    The garage is currently 20ft long by 10ft wide before work. The first job was to remove the leaking roof which I have just completed. I will hopefully start building the stud work and bricking up behind the door in the next couple of weeks.
    Pictures below show the old roof, removed, old window taken out, new roof and new window.
  2. OvertoneBliss
    OvertoneBliss
    Looking good.
    One thing though, the roof looks a little bit "simple", so to speak, is it well sealed so that rain will not leak in etc? Just a thought! :).
    Phil.
  3. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    Had a good soak test. :D The old roof was just corrugated asbestos sheeting. The new roof has had additional joists added to support a bitumenised OSB board roof (gaps sealed with sealant) which then has bitumenised corrugated roofing sheets on top.
    I will be adding insulation above the new plasterboard ceiling once the inside gets under way.
  4. Mr Bump
    Mr Bump
    Jun 3, 2003
    365
    Leicestershire
    +3
    Will be watching with interest! :)
    Just one thing - why didn't you take the opportunity to do away with the window completely? The last thing you want in a HC is one of those bloody things! ;) Or is there to be other rooms in there aside from the cinema?
  5. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    Mr Bump. I totally agree with you and it was my intension to just brick it up. My wife however wanted to keep it so that the room could 'double up' as a chill out area in the summer for get togethers. The room will be decorated to HC standards (dark non reflective surfaces etc) so the only compromise was the window. As she funded the projector it was a small price to pay :) A blackout blind and heavy curtain will have to suffice.
  6. Ray
    Ray
    Oct 2, 2002
    855
    West Yorkshire
    +23
    Blimey - that's what I call a project! When I saw the first few photos it reminded me of the abandoned cowsheds you see in the Dales :D
    But the new roof looks good so I'm sure it'll turn out just dandy! Make sure it's snug and dry and the dpc is in tact. Don't want all that expensive gear rusting from the inside out do we ?
    Good luck
    Ray :)
  7. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    Looking forward to seeing the progress on this, i was a bit dubious about the roof at first but it sounds like you have sealed it well. The dimensions of the garage are really generous as well so gives you good room for a cinema and soundproofing etc.
  8. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    Just added another picture for those sceptics showing how the roof is made up of corrugated sheeting on board :D
    I decided to keep the sheeting style and not felt it to keep in with my other garage on the other side of the property.
  9. john59
    john59
    Aug 27, 2004
    397
    Wigan
    +20
    OvertoneBliss.
    That is exactly what I am going to do but I am having to take down my next door neighbors concrete sectional garage and rebuild it on the existing garage base in my back garden and also remove the asbestos roofing, Thats a good point, where did you get rid of the asbestos roofing.
    I will be watching this thread with great interest keep posting and with loads of pictures and good luck.
    Regards.
    John
  10. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    john59
    The asbestos sheets were removed intact. They are propped up against my house for now. Surrey Heath Borough Council have an appointed site that will take the sheets free of charge (up to six at a time).
    I need to arrange to get them there. It would be worth checking with your local council to see if they have free disposal procedures in place.
    Ty
  11. john59
    john59
    Aug 27, 2004
    397
    Wigan
    +20
    Sorry Ty. posted to the wrong person :( oops.
    Regarding the extra joist, what size did you use
  12. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    I used 7x2 joists as that was what was already there. I figure it will give me 4 inches of insulation and an air gap of three inches once the plaster board has been fitted. Had to go to a timber yard though as B&Q only stocked 8x2.
    Ty
  13. buildbot
    buildbot
    how did u insulate it?
  14. Pieman1972
    Pieman1972
    Jan 6, 2005
    58
    For info - last time I was up the tip - (Portsmouth) they were taking asbestos as long as it was wrapped (they provided the wrap) and placed in the seperate container....
  15. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    Time for an update.
    I had some time last weekend to start putting up the internal stud work.
    My builder friend is very busy at the moment so I decided to have a go at building the wall myself, it's getting there....slowly. Never going to win points for neatness, just as well it will all be covered up with plasterboard :)
    Oh, the drainpipe you can see sticking out of the wall will be for the cabling run up to the ceiling mounted projector.
  16. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    More progress being made.
    Pic 1 shows the insulation slabs between the stud work
    Pic 2 shows the new consumer unit for the room
    Pic 3 shows the first plasterboard fix and floor down.
    Pic 4 shows the screen being fixed.
    The walls will have a second skin of plasterboard. The consumer unit may look overkill but is was cheaper to buy a fully loaded split unit. I have taken the oppurtunity to feed the AV rack, alarm, PJ, lights, outside socket from seperate circuits.
    More pics as work progresses.
    Ty
  17. martian1
    martian1
    Dec 30, 2001
    2,405
    113
    Sunderland
    +660
    Excellent job love to see this one up and running :smashin:
  18. john59
    john59
    Aug 27, 2004
    397
    Wigan
    +20
    Nice to see an update tykent, kep em coming. Hoping to start my project soon.
  19. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    Is that a hint for an invite on the opening night :D
    Its moving now, i bet you cannot wait until its finished.
  20. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    Long time no posting !
    I have gone back to studying so am away for most of the week. I have cracked on when I can at weekends and can now see the light at the end of the tunnel.
    I only have to give the paint a second coat (inzaman should recognise the paint :) ), get the carpets laid and then start wiring everything up.
    Hopefully will be watching the first movie in a couple of weeks, just need to decide on what to watch first :rolleyes:
  21. tykent
    tykent
    Dec 19, 2002
    491
    Camberley, Surrey
    +22
    I have finally finished the conversion. It has taken six months to complete at odd weekends when I have been able to get the time to do it. The following photos were taken today.
    It's been a great help following other people's progress and getting ideas from the forum.
    Now to pour a beer, sit back and enjoy ! :)
  22. john59
    john59
    Aug 27, 2004
    397
    Wigan
    +20
    Nice one matey, nice to see the BEER fridge.
    Enjoy it , I've a long way to go yet but hopefully soon :clap:
  23. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    Looks very smart :thumbsup: like the colour scheme :)
  24. Johnny Thunder
    Johnny Thunder
    Dec 17, 2004
    2,257
    Middlesbrough
    +139
    Very nice job mate......... :smashin:
    Well done.
    Johnny.
  25. Kenny Glasgow
    Kenny Glasgow
    Apr 1, 2004
    3,348
    Livingston, Scotland
    +227
    Tykent
    Excellent job, looks superb, you must be very pleased :thumbsup:
  26. Jamiroquai78
    Jamiroquai78
    Wow, love the colour scheme. Great job! :smashin:
    Makes me want to do it all again (sniff)
  27. louishm
    louishm
    Jun 6, 2005
    2,006
    Manchester
    +57
    :thumbsup: very nice,
    isn't it nice to finally sit down and watch a movie
  28. inzaman
    inzaman
    Dec 16, 2002
    7,962
    Derby
    +1,026
    Oh yes, that first lord of the ringathon in your new room is a pleasure to behold :D
  29. louishm
    louishm
    Jun 6, 2005
    2,006
    Manchester
    +57
    i couldnt of put it better myself.
  30. john59
    john59
    Aug 27, 2004
    397
    Wigan
    +20
    Makes me want to get mine FINNISHED (sniff sniff):eek:
