Another connectivity issue!
Discussion in 'Plasma TVs' started by dazek, May 6, 2005.
  1. dazek
    dazek
    May 4, 2005
    69
    Hi - i have just upgraded my system after 5 or 6 years (of the old one not being touched!) - i seem to have completely forgotten what i knew (which wasn't a lot) - bring in DVD recorders and now I am stuffed!!
    any advice on connecting the following would be gratefully received!!
    Panasonic TH42PE50 Plasma
    Panasonic DMres10 DVD Recorder
    Panasonic Sky Box
    Sony DB STR-DB940 amp
    Mission 6 Pack Speakers
    I seem to be able to connect the RF cables in about 27 possible combinations and scarts in a further 23! (I am leaving my video recorder out of it all for the minute till i get my head around it!) - I also notice my new DVD player doesnt seem to have a co-axial slot - does this mean my £50 coaxial cable is now defunct and i have to use an optical lead???
    many thanks
    darius
  2. dazek
    dazek
    May 4, 2005
    69
    bttt - can anyone at least point me in right direction!
    i have component leads for dvd recorder. do i still connect sky box to the tv via scart and then join the dvd recorder and sky box separately???
    unfortunately the literature for different products contradict each other!!
  3. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    you can connect the Sky box via DVD-r or direct to TV upto you
  4. dazek
    dazek
    May 4, 2005
    69
    is there no quality loss running sky box thru the dvd-r. Can you run the sky box thru the dvd-r even when using component connections.
    r u saying there is no difference doing either???
    thanks for the reply!
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    I'm not saying there is no difference but you can do it (DVD-R needs to be on to do the RGB>YUV conversion and may cause lipsync delay
    I would personally do thie:
    DVDR>Pe50 (component)
    Sky>DVD-R (composite yuk...)
    Sky>PE-50 (RGB scart)
    all audio to AMP inc TV
  6. dazek
    dazek
    May 4, 2005
    69
    hi mate
    pretty much what I have done but have connected sky to dvd-r with a scart. only thing is composite picture from dvd is in black & white!!! more research!
    thanks
    dazek
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    the scart you are using will Be set to s-video or DVD-R out put is, (and composite is the worst PQ so USE component
  8. dazek
    dazek
    May 4, 2005
    69
    sorry - meant component - think its all sorted now mate - thanx for your help!
