another connection ?
Discussion in 'Plasma TVs Forum' started by Mackster, Jan 13, 2003.
  1. Mackster
    Mackster
    Hi Guys,
    Another connection question, sorry. Can I use an IXOS SCART to 4 BNC Component RGB lead http://www.hificables.co.uk/acatalog/SCART_to_BNC_.html) to connect a digi freeview box (Scart) to my Panny TH-42PHD5 ? It states that the cable will only work if my screen can accept a composite sync rather than a horizontal and a vertical sync. Does anyone know if my screen does ?
    Mac
  2. codlord
    codlord
    May 17, 2002
    283
    Portsmouth, UK
    IF (and this may be a big if) the digi freeview box outputs proper RGB, then yes you can, by connecting the sync cable to the panny Composite connector and setting in the menus to 'Sync on Video'.
    This does mean that your Composite input is then used up which also means you can't use the S-Video connector.
