Another confused fella: sub for hi-fi AND AV
Discussion in 'Subwoofers' started by Craig, Oct 29, 2004.
  1. Craig
    Craig
    Apr 2, 2004
    305
    Copenhagen
    +4
    Synopsis; can I use one sub for two tasks, and how ?
    I use my system almost equally (in terms of enjoyment, at least) for 2 channel music and movies. On the music side I am pretty happy (although am starting to realise that my Kandy DVD, good though it is, is being shown up by the B&W's)
    However, on the AV front, the B&W's are struggling a little with movies, and I know I am missing out on a lot of the 'slam factor'
    I'm getting around to thinking about a sub but my concern is that, whilst I am mainly thinking of it for AV purposes, can I use one sub for use in both my 2 channel and my 5.1 setup, and how?
    EDIT:
    For music, I use the Kandy as the main amp
    For AV I use the Kandy amp as a slave to the Yamaha to drive the fronts
    Thus, I am not concerned about WHICH sub to chose.
    I am interested in whether I can / should connect both my main speakers and the sub-pre out from my Yamaha into the sub?
  2. Craig
    Craig
    Apr 2, 2004
    305
    Copenhagen
    +4
    Don't all rush at once, eh? ;)
    Anyway, thanks to some wonderful help and advice from BK - and some less than wonderful help and advice from other manufacturers - I am going for a BK 200
    No doubt I will appear again on the forum when it comes to setting the bugger up
