Another boring overclocking question.....
Discussion in 'PC Gaming & Rigs' started by dynamic turtle, May 5, 2005.
  1. dynamic turtle
    dynamic turtle
    Mar 23, 2004
    1,524
    41
    Central London
    +17
    Do I have to change any voltage settings in the BIOS if I want to add a large fan to my graphics card?
    I'm thinking of putting an Arctic Cooling VGA Silencer on a radeon 9550 (later, a 9800) and need to know if there is enough voltage going through the card's "fan plug socket thingy" to make it work?
    When I say BIOS, I mean the general computer BIOS, not the graphics card BIOS. Do I also have to flash/change the card BIOS too? :confused:
    Forgot to say, the PSU is 460w (should be enough, no?)
    Rgds,
    DT
  2. Miyazaki
    Miyazaki
    Sep 10, 2003
    14,391
    +850
    that is pretty boring.
  3. Joe Pineapples
    Joe Pineapples
    Oct 23, 2001
    7,336
    Doncaster
    +1,130
    :boring: :)
    i have the Arctic Cooling VGA Silencer fitted on my 9800 pro, and it comes with a standard power connector, which you plug into a spare lead from the PSU. So you dont have to do anything with the gfx card, including changing the voltage. As for the 460w PSU, if its a decent quality one, you'll be fine. Mines only a 350, but its a good make, so i know i'm getting some good power through-put.
    btw - where is the 'overclocking' bit in your question? :confused:
    joe
  4. Garrett
    Garrett
    Apr 21, 2001
    39,870
    2
    167
    The best thief you’ll never see.
    +6,531
    No you don't need to edit the voltage setting in the cards BIOS
    the fan on an Arctic cooler uses approx the same voltage; its the design / layout and materials that create more effective cooling.
    if you do have problems, you can buy converters to run it from a 3 pin Molex ( the ones you put in your hard drive ) ( look in Maplins etc )
    or you can also make use of any spare fan pins on the motherboard ( there are usually 2 or 3 on a motherboard ). ;)
