rossglass
I have searched the net but can't find a similar issue.
I recently bought a Nikkai 5.8ghz sender/receiver to share my sat box to another room. The tv with the sat box is mounted on a chimney breast with the receiving tv in the next room (behind the chimney), about 6-7 metres apart. After a lot of tweaking the antennas and channels, the best signal I get is narrow horizontal lines on the screen. Just to add, I disabled 5ghz wireless on my router in case that was causing interference, as it is right behind the receiving TV.
I think the chimney is the cause of this, so I was thinking of buying an extra long scart-composite and power plug and putting the sender in the loft to see if that solves it. Only thing is the scarts are labelled 'sender' and 'receiver', so that must be for good reason.
Does anyone know how to know what scart-composite to look for, or can anyone recommend an easier solution? I had looked at Slingbox but I don't think that will work as the router is not at the TV with sat box.
