another aconda question
Discussion in 'General TV Discussions Forum' started by dsb, Mar 3, 2002.
  1. dsb
    dsb
    any owners tell me-is the bottom of this set flat?
    reason is...i have a limited space to put it in.
    the unit it would sit on is 50cm deep with more empty space at the back.
    so-it would fit in,but,if theres some kind of foot etc right at the far side then it wouldn't be any good.
    if it's relatively flat,then great stuff!
  2. Garrett
    Garrett
    Apr 21, 2001
    43,648
    2
    167
    The best thief you'll never see.
    +8,410
    It has little feet but, mine sits from front to back37cm the rest over hang. Feet across the front 60cm.
  3. dsb
    dsb
    thanks!
