I've read so much about TVs and looked at so many. Im now in total confusion!
At first I thought i'd go with the Tosh WLT68 then decided to spend that little bit extra and go for the panny700 or the sony d3000. Now i've come across the Sammy R87 for £396 and seriously considering to get it as it seems a fantastic price.
I'd be using the tv for SD tv and for the xbox 360. Would you guys recommend I go for the sammy or spend £300 extra and get either the sony or panny. Is it worth it? Would the sammy do the 360 justice?
