Annoying start up and shut down noise CX65
Discussion in 'Mobile Phones Forum' started by Tibbs, Feb 25, 2005.
  1. Tibbs
    Tibbs
    I have just got a new Siemens CX65 on BT Mobile, and when I switch it on/of, it comes up with a BT Mobile Logo and plays an annoying tune.
    Is there any way I can get it to stop doing the noise? I will often need to switch it on/off in a quiet environment and the beeping will be very invonvenient.
    Many thanks,
    Chris
  2. brado
    brado
    Jan 16, 2004
    130
    16
    Worcester UK
    Press menu, use joystick to select spanner; press centre button; select Ringtones; select more melodies; select Shutdown Melody and press left dot to shut off.
    Hope that helps. You reminded me to do mine.
    Alan
