Annoying registry popup
Discussion in 'Desktop & Laptop Computers Forum' started by Greg Hook, May 29, 2005.
  1. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    20,709
    In a secret location with Jennifer Lawrence
    +7,492
    Got an annoying pop up that keeps appearing on my Mum's laptop.
    Message such as the system registry is corrupt, or 47 errors have been found.
    It keeps giving a different website address each time to go to fix the registry. I can't see there being anything wrong with the reg as the pc works fine. This looks like some dodgy popup to me. I haven't been to the websites mentioned incase something nasty happens.
    Latest website was e-regpatch.com and another www.PCRegFix.com
    Any ideas?
    I have already run adaware but it didn't find the problem.
    Greg
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,128
    Manchester
    +715
    Yes, you have a trojan at work here.
    See if the latest Adaware and/or virus checkers will remove it.
    Chris Muriel, Manchester.
  3. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    I am currently using Microsofts(yeah I know!) Giant Beta Antispyware program,which is currently free and personally I think is very good :thumbsup:
    It has 'realtime protection' which monitors your PC and warns you about anything dodgy going on.
  4. dekoded
    dekoded
    Oct 30, 2004
    893
    Blackpool
    +45
    Sounds as though you have the messenger service running (not MSN messenger), use administrative tools (start/control panel/administrative tools/services) do disable this service which will stop those annoying pop-up messages.
  5. smelly
    smelly
    Oct 16, 2004
    1,598
    Bristol
    +102
    I get exactly the same on my laptop - I think only when I go to one particular site - TVTome - so I thought it was a pop up just linked to that site. Adaware and AVG haven't picked it up and my laptop seems to be working fine so I just close it every time.
    My messenger service is already disabled but it still pops up. Its the only one that does. :confused:
  6. Greg Hook
    Greg Hook
    Nov 25, 2001
    20,709
    +7,492
    Thanks all, I will give my Mum some things to try out. It is more of a nuisance than anything.
  7. ClumsyBiker
    ClumsyBiker
    Any popup that occurs spuriously in Windows, and wants you to visit some website to get a "fix" tool or utility is to be regarded with the utmost suspicion.
    Both the suggestions from this thread of trojan infection, and messenger service are possible.
    Here are some excellent tools I use whenever I put a PC together for someone - all are free to use, or are available in free versions:
    Anti-Virus: AVG from grisoft
    Anti-Spyware: Ad-Aware Personal SE from lavasoft , Spybot-Search & Destroy and a copy of CWShredder is always handy, because if you get the CoolWebSearch spyware on your machine it's a complete b*tch to get rid of.
    Good luck!
    Clumsy. :D
  8. Slinkoff
    Slinkoff
    Oct 14, 2004
    697
    28
    +24
    i second those recommendations from Clumsy. Spybot combined with Adaware remove everything and Spybot's registry watcher makes it hard for any new spyware load itself in your registry. The best defence of all is to switch to Firefox. And consider disabling javascript.
