Annoying Hum sound!!!
Discussion in 'Home Cinema Buying & Building' started by chris.hesketh, Jun 30, 2005.
  1. chris.hesketh
    chris.hesketh
    Hi all
    I am new to this, so sorry if this sounds a little backward. I have a samsung DVD player, and a Goodmans home cinema 5.1 amp.(GHC56Pro) I have got the DVD connected to the amp via a coaxial lead, and to the TV via scart. The problem is when I use the surround sound, with DVD, when the film sound is low, I can hear a hum/Sussh noise coming from the speakers. This sounds somewhat like the DVD spinning!!!! This does not happen if I connect the DVD player to the goodmans unit via normal phono plugs rather than the Digi output. I have the DVD audio output set to bitstream, on DTS and Dolby Digitaol Audio. I also have audio settings for dynamic compression, and PCM down sampling!! Anyone any advice??
    Rgrds
    Chris
  2. inzaman
    inzaman
    Dec 16, 2002
    7,959
    Derby
    +1,023
    Moved to all in one systems :)
  3. LarryS
    LarryS
    Jan 27, 2005
    I would suspect a defective connecting cable. Also, try having the mains power for the three units provided by single powerstrip. Hum is ususally caused by poor connections or ground loops or both. Hope this helps.
    Larry S
