Annoying buzz
Discussion in 'Hi-Fi Stereo Systems & Separates' started by Frosticles, Dec 21, 2006.
Tags:
  1. Frosticles
    Frosticles
    Jan 31, 2006
    24
    Near Nottingham
    Hi there, I am currently experiencing a really annoying buz from my Hi-Fi when I connect either my LCD TV or DVD Recorder to the pre amp. pre/power amps are Arcam alpha 9's btw. When my CD player is connected all is fine but as soon as either the tv or dvd is connected then this buzzing occurs which will not go away even with the sound switched off. Sounds to me like an earth fault but I have changed leads and have tried the components in all of the inputs to no avail. Anyone have any ideas p;lease? Many thanks, Kev.
  2. leon
    leon
    May 15, 2001
    1,160
    kent
    +67
  3. Frosticles
    Frosticles
    Jan 31, 2006
    24
    Near Nottingham
    Hi there, have been advised by the people you mentioned in the link to get a Ground Loop Isolator. have bought one and will try and see if it cures the problem this evening. Thanks for your help, Kev.
