annoying buzz from new Jvc Av-28r4skc
Discussion in 'General TV Discussions Forum' started by jay2, Sep 17, 2004.
  1. jay2
    jay2
    Just bought a new Jvc Av-28r4skc tv! Good Picture,Great sound but it has most annoying buzz comming from back and from the vents on the bottom and sides!
    Its really noticable when the volume is down and even when the sound is up on silent parts of a film/programe.
    It sounds like a Electricity/power type of buzz!
    I have been back to the shop and the one on display makes the same noise!(hard to hear in a busy shop but its definatly the same noise)
    Do all tv,s make this type of noise? Can`t remember my last one doing it!
    Is there anything I can do to make it a bit quiter?
  2. sbass1
    sbass1
    i have just bought a toshiba 28zd26p 2 weeks ago and it buzzes just like yours! picture and sound great , tv looks fantastic but it buzzes and is audible at low volumes , especially late at night. Retailer said it was becauase it is 100hz , but im keeping my options open at the moment.Has anyone out there got same problem with their toshiba?
  3. jay2
    jay2
    Sounds like the same noise! You`r right seems worse at night probably due to lower volume (kids in bed).
    Mine is only a 50hz?
  4. peahead
    peahead
    Dec 14, 2002
    2,991
    St.helens
    +375
    i had a jvc tv that buzzed aswell and it went away after a few weeks once it had been run in might just take a bit of time .
