Annoying 5.1 output on PC games.
Discussion in 'PC Gaming & Rigs' started by RiGoRmOrTiS, Sep 3, 2004.
  1. RiGoRmOrTiS
    RiGoRmOrTiS
    Aug 10, 2004
    371
    +43
    There seems to be an annoying problem with 5.1 sound on PC soundcards and its really starting to annoy me.
    I'm currently using the creative audigy 2 and I can get 5.1 sound out of the digital output when a DD or DTS audio stream is being used in applications such as my DVD software. However when it comes to a computer game or video that has a 5.1 soundtrack that is in neither DD or DTS I can't get all 5.1 channels to output.. just stereo.
    This appears to be because the digital output on the card can only output actual digital streams, while analog 5.1 provided in games and some videos require you to use multiple analog connections from the soundcard to each speaker.
    What i want to know is, is there a program out there somewhere that can intergrate into windows and take these crappy 5.1 tracks and combind them into a dolby digital stream? This would allow the soundcard to output all 5.1 soundtracks through the digital output. if it converted all sound in windows into a dolby digital stream that would be superb.
    So my question is.. does such a program exist.. and if not.. why not?
  2. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    nope.
    1) licencing
    2) it would grind your cpu to a hault.
    3) just isnt worth it.
    If you want ac3 5.1DD from your games get a soundstorm eqipped motherboard. Other than that your stuck with using analogue connections. This has been covered many times. a search would have given you you answers:)
  3. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,489
    South Derbyshire
    +198
    Soundstorm equipped motherboard - I love it.
  4. AML
    AML
    Jul 22, 2004
    4,989
    Tokyo
    +228
    you should check out my thread on Dolbu Digital in games! I had similar questions about why some games say they offer DD5.1 but they actually dont tell you how to get it.
    My thread is called: Dolby Digital?
  5. james.miller
    james.miller
    Dec 16, 2002
    2,616
    +143
    :confused:
