Angel Season 1 Problem
Discussion in 'Movie Forum' started by adamp, Jan 28, 2003.
  1. adamp
    adamp
    Hiya,
    I'm having problems with my Angel Season 1 boxset. I know this has been discussed before, but I can't find this specific problem.
    On disk six, the last episode won't load most of the time, I have got it playing once - stopped it, then it wouldn't resume. Sometimes the disk won't load at all.
    I've cleaned my lens and the DVD to no affect.
    I also get a similar problem with my Buffy (R1) boxsets (although not as bad). Also didn't notice it first time I watched Season 2.
    I'm using a Pioneer 444 player.
    BTW Angel plays fine on DVD-ROM, and all my other disks play fine on the Pioneer.
    Does anyone know if this is a player problem/disk problem/combination of both.
  2. Stinky985
    Stinky985
    Jun 12, 2002
    674
    Nr Bath
    +6
    just out of interest is the angel R1 or R2?
    I have just ordered the R2 season 1 and will looko out for the hassle when it arrives.
  3. adamp
    adamp
    It's region 2 from dvd.co.uk
    I'm going to contact them today and see what they say!
    I went through the whole set last night and I've got problems with disk 2 and 3 aswell!!!!
  4. Stinky985
    Stinky985
    Jun 12, 2002
    674
    Nr Bath
    +6
    let me know what they say!
    I'll check all mine when i get them
  5. kev_melon
    kev_melon
    Sep 26, 2002
    55
    9
    I'd rather not say...
    I have the R2 boxset of season 1 and I tested all the discs on both my DVD players (LG4710 and Toshiba SD220) and my friend's DVD player( Arcam DV27).
    No faults with discs or player incompatibility on any player so it could be that there is a fault in the boxset that you own. Contact dvd.co.uk and see what they have to say on the matter.
    All the best, and let us know how you get on.
  6. adamp
    adamp
    I've spoken to dvd.co.uk and they've told me to send the offending discs back, and thay'll send out replacements.
    Fingers crossed.
