Angel Season 1 Boxset (Region 1) - Serious Bass
Discussion in 'Movie Forum' started by Apocalypse, Feb 21, 2003.
  1. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    has anyone else noticed the astonishing bass extension on this box set, it's right up there with the best movie soundtracks in terms of low extension. Bear in mind it's only a 2 channel mix as are most TV soundtracks so it's very impressive. When I switch to Angel season 2 on Region 2 the sonics are tame as is expected on a TV series, the same thing goes for Buffy box sets both region 1 & 2.
    Has anyone else discovered this, you should note that the bass I'm talking about is the kind of bass that isn't heard but felt (trouser flapping). I feel cheated now with the inferior Reg 2 box set but I suppose that's to be expected with crappy reg 2 anyway.
    Phil
  2. James45
    James45
    Sep 21, 2002
    2,844
    59
    Taking Care of Business
    why less bass on R2, is it PAL speed up?
  3. Apocalypse
    Apocalypse
    Aug 14, 2002
    840
    19
    Sheffield
    No idea, the difference is very very obvious though, untill the season 2 reg 1 of Angel is released we'll never know if it's superior reg 1s or if this particular boxset is just blessed. Can anyone with the reg 2 version of season 1 comment on the lfe, is it superior to season 2 (reg2)?
    Jeez, all the diff numbers in this post have confused me :suicide: :laugh:
