andy
Discussion in 'Arcam Owners' Forum' started by Andy_dot@blueyo, Jan 15, 2005.
Tags:
  1. Andy_dot@blueyo
    Andy_dot@blueyo
    I have just added a arcam dv88 to my set up,but now have a small problem.
    When in av mode I am now getting a high pitched buzzing noise from my front speakers which does not happen when the amp is switched to cd or vcr.
    This noise is noticeable within 1mtr and is constant over the volume range. Could this :confused: be a tv or connection problem as when the the tv is turned off the noise disappears as well?
  2. rOAdeh
    rOAdeh
    Jan 24, 2003
    648
    Winchester
    +5
    might be a ground loop? ...i would be more certain but i'm not sure if it is a ground loop if it only affects one source.
