Android to Android file exchange, no bluetooth
Keithhampson
Hi how can I exchange files between my HTC sensation and my ployer momo11 tablet?both run Android but my tablet has no Bluetooth, I could mess around swapping sd cards or hooking each up to a computer but don't have much access to computers, is there a remote way to exchange the files? Some files are quite big500 MB+ so what are my options?
Keith
nvingo
What facilities do you have?
If you have broadband then you probably have a wifi router so both devices might be able to link up through that.
Keithhampson
Hi, all I have is a mobile phone and a tablet, I use the wifi hotspot on my phone to go online with my tablet.
Keith
limegreenzx
Keithhampson said:
Will it take 700mb files?
Yes, but it will take forever to sync between the 2 devices. Does either of your devices support usb otg (on-the-go). You could then plug them together for file transfer.
m1ket
There are lots of apps that can share over wifi if you have a wifi network to connect them to
