Concho
Thought I'd share this to show what I've just done in my Mazda 3 and maybe get some ideas on what I can add, do next.
I have a Mazda 3 sport, 2008 model with Bose, but wanted something a bit more. I was looking at the Chinese Android head units for quite a while but after a lot of research and debating with myself I went for an Android tablet instead.
I bought an Asus Google Nexus 7 tablet from ebay, second hand for £100 or so (with 3G), a sim card from giffgaff for cheap data every month, and a fascia kit on ebay for £17.
I then took a dremel to the fascia kit to sand it down so the tablet could sit quite close to the front, otherwise there would be a fairly big indent in the dash. I stuck it all together in a very high tech method - duct tape!! I decided I wanted to keep my current radio in and the full use of the info screen so I decided to power and plug in the tablet by normal car charger and 3.5mm plug, but wired these through the back of the dash under the handbrake and into the armrest, pretty easy really. I took the front fascia off the radio and tested it still worked, everything was fine and I still have all the control I want over it from the steering wheel controls.
The tablet is using an app called Tasker to come on when it receives power (when key is turned), and turn off when it loses power (turn key off)
Apps wise, I have Sygic & Waze for sat nav, Tune in for radio, Youtube and a few other for when I'm waiting to pick the missus up from work!
It was a very tight fit with the radio sitting in it's normal place and I could have done with a fraction more depth in the cavity, but for a first effort it's ok.
Here's a few pics, I did unfortunately scratch the fascia when sanding but I'm not too bothered as I'm glad I managed to do it, and I may end up buying another fascia as the first was more of a test.
