Hi, I've a CRT TV that I'd like to connect a small media box to so that I can stream videos primarily Netflix and apps within XBMC. As a bonus I'd like to be able to run Twitch TV and the UK On-demand services.
Initially, I was considering a Raspberry Pi and run XBMC off it, however the lack of Netflix is unfortunate. I've also looked at devices like Roku (no XBMC) and Apple TV 2nd gen (too expensive). So then I discovered you can get Android mini pcs on a memory stick like the MK808. These look great but unfortunately they only have a HDMI out so no support for CRT TVs.
So would anyone be able to recommend any other Android Mini PC boxes which support A/V out also? Ideally my budget is around £50-£80 but I'll consider any recommendations. Thanks!
