And the lights go down...and back up again!
Discussion in 'Home Cinema Buying & Building' started by Les E, Jan 13, 2005.
  1. Les E
    Les E
    Oct 5, 2004
    963
    St. Helens
    +18
    I have been advised previously that if I want to have a dimmable light system (mixture of halogen spots and uplighters) in my home cinema set-up, it would best to buy 2 varilight remote dimmer switches.
    Mainly because I want the lighting to fade down on the start of a film and back up at the end, then it has been suggested that the remote macros would control this when turning the system on.
    However, I have a varilight remote dimmer in the living room and although I can control the up and down fading by keeping my finger on the remote and a short tap to switch on/off, I cannot see how this would work on a macro system?
    To get this kinda effect, would I better to puchase a Futronix dimmer to control the fade up/down or should I be looking at another type of dimmer system (but not too expensive!!)? ;)
    Or is it totally a remote issue?
