And another thing!
J
JetJockey
A mate of mine, whilst staring over my shoulder at the computer monitor asked, "how do you feed the BNC output signal from the Lumagen (RGBHV) into the Fujitsu as it only has three BNC connections (Component)".
I must admit, this stopped me short as I could not think of a suitable answer. :confused:
Gerald. :)
S
Sharpy14
I could rthink of a suitable answer, but he wouldn't be a friend thereafter (does he wear an anorak perchance?) :D
Joe Fernand
AVForums Sponsor
Hello JetJockey
In-Flight Internet Access :)
A decent 5BNC to HD15(VGA) cable will be required.
Best regards
Joe
Piers
Output RGB rather than RGBHV from the Lumagen? Slightly dependant on which Lumagen and which Fujitsu!
J
JetJockey
Hello all.
Yes Sharpy 14, that was my first thought. Unfortunately he's a lot bigger than me. I could have ended up wearing the computer monitor! :oops:
Hi Joe. Thought you had disappeared off the face of the planet. I had stabbed a guess at one of those leads.
Piers, I thought those Fuji inputs were component (but not RGB component).
Gerald. :)
Trending threads
