Anatomy
Discussion in 'Movie Forum' started by Brigadeer, Apr 28, 2002.
  1. Brigadeer
    Brigadeer
    Any views on this German horror film...worth a purchase ?
    Thanks.
  2. European
    European
    ...rent if you can... this quite mediocre 'slasher' movie has little if any 're-view' value... imnsho, of course...
    . . . :eek: . . .
  3. PoochJD
    PoochJD
    Aug 28, 2000
    10,992
    Norwich
    +1,861
    Hi All,
    "Anatomie" (to give it its original German title) is an okay horror-thriller.
    The idea is an interesting one, and the small amount of SFX are quite good, but as others have said, the film is not strong enough to withstand repeated viewings.
    Franka Potente (from "Run Lola Run" and "The Princess And The Warrior") is quite good in it, and is seen here, with her natural hair-colour and style, unlike the other two movies mentioned.
    Admittedly, the UK DVD is uncut, in 16:9 widescreen, and has a reasonable amount of extras, which helps make the disc a little bit more worth your money.
    Pooch
