Anamorphic Widescreen
Discussion in 'LCD & LED LCD TVs Forum' started by tomandjo2, Mar 23, 2006.
Tags:
  1. tomandjo2
    tomandjo2
    Jan 3, 2006
    480
    +17
    I have just received Le Mans (Steve McQueen 1971) on R2 DVD.
    The DVD has an aspect ratio of 2:35:1 Anamorphic Widescreen.
    Everything is ok (pre movie credits fill screen) until the movie itself is playing when aspect changes so there is a thick black border around all 4 sides of image.
    The only way I have been able to fill the screen is to Zoom in 133% which cuts a very small amount of all sides.
    I would have expected the image to be automatically stretched to fill the screen.
    Any help appreciated with this minor problem.
    Thanks in advance
    Tom
    JVC 32DS6 with Tosh 150E DVD player component/prog scan.
  2. stefmcd
    stefmcd
    Nov 7, 2004
    591
    +7
    Sounds to me like your tv is switching into 4:3 mode. That's the only thing that would explain bars at the left and right.
    To test the disc play it on a pc and see what aspect window comes up - it should obviously be a 16:9 ratio - and have black bars top and bottom.
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,724
    Somewhere in South Yorkshire
    +6,299
    Have you got your DVD player set to output 16x9? What you describe sounds like it isn't.
  4. tomandjo2
    tomandjo2
    Jan 3, 2006
    480
    +17
    I've tried it in a mates laptop and it played full width with black bars top and bottom so will check TV and DVD settings this eve.
    Tom
  5. LV426
    LV426
    Jul 14, 2000
    13,724
    +6,299
    With a film in ratio 2.35:1 you should expect black bars top and bottom. You should not expect any at the sides, and everything in the film should be the right shape - not too fat nor tall, circles round etc..
  6. tomandjo2
    tomandjo2
    Jan 3, 2006
    480
    +17
    I have tried a few different things, laptop full width picture bars top and bottom, our other DVD player (cheepo one) full width picture but double size black bars top and botton so vertical picture only takes up 1/3 of screen.
    Our 150E even when playing with settings best option is as reported with zoom or leave as is.
    It would appear that rather than stretching the 'un-stretched' vertical part of the picture it's shrinking the 'pre-stretched' horizontal part of the picture to correct the aspect ratio.
    Tom
  7. LV426
    LV426
    Jul 14, 2000
    13,724
    +6,299
    The most common cause of "full width picture but double size black bars top and botton so vertical picture only takes up 1/3 of screen." is that the DVD player is not set to output 16x9 where present on the disc. This is typically a menu item and may be referred to as TV shape or similar. Set it to 16x9 or wide.
    But then, I've told you that already.
  8. russ123
    russ123
    Jul 31, 2004
    841
    46
    South Of The River
    +119
    I just had this problem with my projector. Turned out it was a pal/ntsc mismatch. It is not an NTSC disc by any chance?
  9. Helterskelter
    Helterskelter
    Hang on! I think the film was made that way,as was the film Grand Prix
    Occasional masking top bottom and on the sides.
    Meant to be 'artistic' in those days.
    Try playing it on a friends dvd/crt setup.
    eddie
