R
rockhard
The CEDIA show featured alot of display manufacturers showing autoscoping add on anamorphic lense systems.
I have a 110" diag screen which translates to height 54" x width 96" ( 4.5 ft x 8 feet ) I want to maintain the constant height with variable width using a panamorphic lense from Prismasonic .
So the next screen purchase will be a 2.35:1 cinemascope screen 54" x 126" ( 4.5 ft x 10.5 ft. )
With the Prismasonic you can use the optics ( rather than the scaler electronics ) to black out the bars on either side when showing " pass through mode " 16 x 9 aspect ratio . This makes your 2.35:1 screen look like previously mentioned 16:9 54" x 96" ( 4.5 ft x 8 ft ) screen.
The beauty of this is no remote controls , automatic mechanical movement of lense into place or masking screens needed.
This will become even more important when we get into HDTV widescreen movies and will preserve even more resolution ( 30% loss without lense ) of HDTV 1080P vs 480i DVD that we now use .
AVS link on subject here :
Prismasonic anamorphic lenses -
http://www.avsforum.com/avs-vb/showthread.php?t=578367
All I can say is I want one ...
Prismasonic anamorphic lens is a high quality optical product to boost
your digital projector to the next level. It makes a variable horizontal stretch to the projected image, and thus supports perfectly the constant height, 2.35:1 CinemaScope setup, which is also used in the real movie theatres
