I have a Isco II lens and want to somehow install a slide directly to my projector.
Is there a slide out there that would allow me to do this?
My projector mount is quite long and to install the lens in front of the projector at the same length would look a bit out of place in my living room.
I know Panamorph do a lens slide which connects directly to the projector but i guess it only works with their lenses.
Any suggestions would be helpful.
