Quantcast
Anamorphic lens question.
ilkand
I have an anamorphic lens for my 1024 x 768 pj. What resolution should i set the output of Zoomplayer to? 1024 x 576; 1024 x 768 or 1024 x 1024.
(I have sort of tried them all but with no definitive answer).
Aspect ratio is Anamorphic, is this right?
I also use ffdshow resize sometimes. Should I resize to the same as the desktop?
Thanks for any help
Andy
Jeff
You keep to the native res of the projector and uncheck the keep aspect ratio on the player. Without the lens in place the picture should look stretched vertically (tall skinny people). Then depending on the type of anamorphic lens, the picture will either get streched horizontally or squished vertically.
