analogue!!!!!!!!!!!!!!!!
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by oldguy, Mar 29, 2005.
  1. oldguy
    oldguy
    Feb 21, 2005
    42
    rotherham
    Help anyone,
    want to transfer my analogue videon fottage onto my PC using windows Movie Maker -
    Is there any hardware compatable ?
    Most of the stuff I've seen comes with it's own software, But having put a load of digital footage thro' movie maker i am quite happy with the results and ease of use provided by Movie Maker.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,121
    Rainham Essex
    +2,389
    If you have a digital camcorder that has AV-in enabled then you can use it to convert the analogue source to digital and then pass on to the PC via firewire to be captured by Movie Maker. Just make sure you set MM to disable device control, otherwise it will try to rewind the tape in the camcorder which wont work as you wont have one in there.
    If you do not have an AV-in enabled camcorder then it is a matter of useing other hardware to convert the analogue video to digital either with a capture card or a analogue to DV converter. Once captured MM can then be used for editing.
    Mark.
