Analogue video capture
Discussion in 'Desktop & Laptop Computers Forum' started by Darren Blake, Dec 16, 2003.
  1. Darren Blake
    Darren Blake
    Apr 28, 2003
    620
    Norwich, UK.
    +15
    I was trying to capture a ten minute (approx 4Gb) segment of video from a VHS recorder last night to encode it onto a VCD. Almost got it to work but hit a small snag.
    Bear with me as I cannot remember the exact resolutions, but my capture card drivers come with several preset resolutions for the captured video. The one I wanted to use was the same as PAL VCD. There was also a setting "one below" this which seemed to be the closest res which used nice round numbers.
    My problem is that I want to capture at at least 25fps. If I used the "one below" res then I could do this easliy. However, if I changed to the PAL res setting, the framrate dropped to a measly 10/12fps. what the fudge????
    My setup is as follows:
    PC: 1.7GHz processor, 256Mb DDR RAM.
    Capture card: Pinnacle systems, capturing through composite.
    Cature target disk: 80Gb 7200rpm 2Mb cache.
    Why, just by tweaking the res up slightly, does the framerate drop by 50%?
    TIA.
  2. Magsy
    Magsy
    Oct 18, 2002
    107
    What software are you using? Capture to mpeg1 I assume?
    With a cheap pb-tv100 from pcworld, using Mainconcept mpeg encoder on a p4 2.6 I can do realtime mpeg2 @ 720x576 (D1 - full pal) at any bitrate. So I'd guestimate yours should be fine with a quarter of the information in mpeg1.
    Pal vcd should be something like 352x288 mpeg1 @ 1150kbps.
    Could well be its changed more than just the resolution, maybe its upped the quality of encode (usually just a small slider) which can make a huge difference. (speed vs quality tradeoff)
  3. Darren Blake
    Darren Blake
    Apr 28, 2003
    620
    Norwich, UK.
    +15
    Capture is to AVI. No recompression. Res is just under 352x288 (can't recall the exact value). Software is Vidcon32 through a Pinnacle PCTV analogue card.
    Someone else has told me that the amount of data being passed to the disk may be more of a limitation, hence compressing on the fly may yield a better framerate. I had assumed that the less processing the machine had to do in real time the better.
    Will experiment tonight.
    Cheers for the reply!
  4. Darren Blake
    Darren Blake
    Apr 28, 2003
    620
    Norwich, UK.
    +15
    FIXED! :D
    Data throughput was the problem. Indeo compression set at 85% quality lets me grab at 352x288 res at 25fps.
    Sorted. Cheers!
  5. Magsy
    Magsy
    Oct 18, 2002
    107
    Urgh, if that HD cant do quarter pal uncompressed you have a problem!!
    I have run of the mill 7,200rpm drives and they will quite happily do full pal.
    Surely indeo is ruining the quality? Quite an old codec.
    Try using huffy yuv , its highly regarded as the best lossless codec. Effectivley retaining the uncompressed PQ but at a lower data rate (not much but enuff) This should then turn quite nicely into VCD.
  6. Darren Blake
    Darren Blake
    Apr 28, 2003
    620
    Norwich, UK.
    +15
    I'm fairly happy with the quailtiy of the capture, but I've yet to do one "in anger" and turn it into a VCD.
    Could you give me a rundown of your hardware / software? I can't make out whwther you are using a hardware MPEG-2 encoder or not. There's no way my machine could do real time MPEG 1 let alone MPEG 2, so I guess you must be using hardware?
    The people who told me it may be data throughput to the disk were the support forum operators at Puremotion (who's video editing software I use).
  7. Line_Man
    Line_Man
    Dec 17, 2003
    46
    I think MPEG 2 is SVCD
  8. Magsy
    Magsy
    Oct 18, 2002
    107
    You can do realtime Mpeg 2 on a resonable machine, obviously the faster it is the higher quality you tend to get. Mpeg1 realtime is no prob at all. I used a P3 733 at my GF's house to do realtime SVCD for ages (PVR), I then stuck a 1ghz P3 in and it wud just about do 720x576 mpeg2. This was with Cyberlink Power VCR II.
    I have nothing special, the much talked about cheapo pc world capture card and a P4 2.6 with 2 60gb drives (no raid..) I'm using Mainconcept Mpeg Encoder though, it costs good money unless you can 'aquire' it somehow :p
    Disk throughput could be the issue, but what I'm trying to say is that you shouldn't suffer it at such a low rate. Try huffy if you arent happy with the quality!
  9. Darren Blake
    Darren Blake
    Apr 28, 2003
    620
    Norwich, UK.
    +15
    Can you tell me a bit more about your capture card please? Just to be 110% sure, you are talking about analogue capture aren't you? Not DV?
  10. Magsy
    Magsy
    Oct 18, 2002
    107
    Yea, analogue via svid from sky+
