analogue tapes to dvd recorder
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by grayt60, Oct 20, 2004.
  1. grayt60
    grayt60
    i have 8mm tapes and wish to convert to dvd.
    i have tried a straight connection to panasonic dmr-e30
    In sp mode i end up with frames half picture and half black screen when i take it to edit on my pc.
    would i need to run the connection thro an analogue to digital convertor first
    thanks for your time.
    grayt
  2. johnjackthom
    johnjackthom
    Sep 20, 2001
    707
    46
    Northumberland
    +236
    Hi Grayt, do your camcorder dub recordings play back OK on the E30 and are you recording onto DVD-RAM discs or DVD-R?
    It may be that your editing software just doesn't like mpeg2 files.
    John
  3. grayt60
    grayt60
    johnjackthom
    yes they playback fine on the e30 no problems and yes recording to dvd-ram
    i`ll try different software
    cheers grayt.
