Analogue Sat. Amstrad srd 500
Discussion in 'Satellite TV, Sky TV & FreeSat' started by JT, Jan 12, 2003.
  1. JT
    JT
    Jul 18, 2000
    137
    +4
    Hi, I've just aquired this old sat, to replace my pace which bit the dust, to watch the German channels, and I'm having major problems trying to tune it in. When I think I've saved a channel to a channel No I can turn the sat off and on in a short space of time say half hour and it stays there, but anything longer and it's gone.
    I,m trying to do this via the front panel as I have not got a remote,
    Any ideas?
    John
  2. Fernsehman
    Fernsehman
    As I recall, there's no "store" button on the front panel. You have to use the remote control. You may be able to order one from satcure if they still stock them.
    Fman
  3. JT
    JT
    Jul 18, 2000
    137
    +4
    thanks Fernsehman.
    There is no store button on the front, just a "preset" button, which I hoped was the same. Never mind.
    John
  4. Fernsehman
    Fernsehman
    Actually, now that you mention it, I'm fairly sure that Amstrad did use "Preset" for "Store". You press "Preset" and the display flashes. Alter the settings and then press "Preset" again?
    Really taxing my memory!
    Fman
