Analogue out to DV in transfer
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by cunningham, Jan 6, 2002.
  1. cunningham
    cunningham
    Can anyone tell me if it is possible to transfer Analogue 8mm footage to DV tape using Analogue camcorder ( connection for copying to VCR) to DV camcorder ( Analogue in )without using any other editing facility.
  2. Arthur.S
    Arthur.S
    As long as your DV cam has analogue in, then yes. You just use the record functions on the DV cam as you would a VCR.
