Analogue or digital
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by mammoth, Jun 19, 2003.
  1. mammoth
    mammoth
    Feb 25, 2003
    121
    16
    birmingham
    Can anybody tell me which format to go for?
    I have hi 8 tapes so need to be able to view them but do I go for analogue or one of Sony's digital 8 camcorders, What are the pro's and con's of digital?
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,854
    71
    Worcester
    +21
    Go for D8 DV quality and plays back Hi8
  3. Duster
    Duster
    Dec 4, 2002
    421
    UK
    Analogue Camcorders will be cheaper, but there are not many on the market now, as digital has taken over.
    Like MartinImber says, get digital 8 if you want to play back your old HI8 tapes.
    Watch one for which digital 8 camcorder you buy, as some of the cheaper ones dont support HI8 play back. So ask before you buy.
    Good Luck
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,350
    Rainham Essex
    +2,441
    Digital pros:
    smaller/lighter cams, better quality, more features, easier to get video onto PC for editing,more choice of cams
    Digital cons:
    more expensive, tapes more expensive, lower battery life, most not good in low light
    Mark.
  5. mammoth
    mammoth
    Feb 25, 2003
    121
    16
    birmingham
    Thanks for the advice, I have my eye on SONY'S dcrtrv250 does anybody have any first hand experience of this model or model's around the £350 price mark?
