Analogue inputs
Discussion in 'TAG McLaren Audio Owners' Forum' started by m0v1em4n, Dec 8, 2003.
  1. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Hi all,
    I am thinking about get the SoundBlaster Audigy 2, but believe that in order to get 192 hz i will have to use the analogue input on my Tag AV32r,
    What are the positives and negatives of using analogue inputs?
    i have read some where that the sound format just shows as stereo, is this true
    tried to do a search on the tag forum but its not very good at the moment.
    steve
  2. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    Steve
    can you explain a bit more what you are trying to do here?
  3. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    As Beekeeper says,exactly what are you trying to do?.....if you're hoping to pipe DVD-A out of the Audigy and into the Tag,you won't get a decoded digital output,as all the processing is done on board to preserve copyright.
    It would also be helpful to know which AV32R you have....i.e.does it have the analogue bypass upgrade....?
  4. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    First my Tag does not have the bypass, and I use an HTPC for all my DVD and music, I mainly watch films but on the odd occasion I would like to listen to some music
    What i was trying to achieve is
    play and decode DVDaudio via my HTPC and pass it to the Amps via the Tag but also still preserve the ability to pass 7.1 film sound tracks to the Tag for decoding,
    I understand that the bypass would be the ideal solution,
    last night i tested an Audigy 2 via the Spdif and i was getting 96hz reading on the tag but the sound format was showing stereo, but the track being played was in 5.1, just thought that if I used the analogue input I would then get the 5.1 :confused:
    Thank
    steve
  5. alexs2
    alexs2
    Nov 13, 2002
    13,896
    +1,674
    The analogue inputs on a non-bypass AV32R will simply run in stereo,and will be converted internally to digital form before being reconverted to analogue again prior to output,so unfortunately that idea wouldnt work.
    The analogue bypass option is really the only way of getting it to work in the way you wanted.
    The Audigy decodes DVD-A internally and outputs analogue multichannel,and will not output high-res digital data via the digital outs in order to comply with copyright concerns.....as far as I know that is!
  6. m0v1em4n
    m0v1em4n
    Jul 1, 2001
    819
    Derby
    +48
    Thanks Guys for the info
