Analogue/Digital interconnects
Discussion in 'Cables & Switches' started by bones`, Mar 20, 2005.
  1. bones`
    bones`
    Oct 12, 2002
    1,961
    Preston
    +47
    Just wondering what the difference is between the two. I know digital should be 75ohm but is it ok to use digital as an analogue interconnect or visa versa?
  2. Reiner
    Reiner
    Jul 16, 2000
    3,316
    61
    Germany
    +13
    Digital: 75 Ohm (same as proper video cables actually)
    Analogue: 50 Ohm
    Generally I would advise to use the correct cable though you can use them as replacement for each other, it does (usually, mostly ...) work.
    Some people claim to hear a difference, in particular when they listen to CD via a 50 Ohm cable used for the digital connection.
  3. bones`
    bones`
    Oct 12, 2002
    1,961
    Preston
    +47
    Thanks Reiner. I just bought an amp and the only interconnects I had to hand were some decent 'digital' ones. They seem to work fine but until I get some decent analogue ones I won't know. :thumbsup:
