Analogue cables
Discussion in 'Cables & Switches' started by Dfour, Sep 7, 2004.
  1. Dfour
    Dfour
    Jan 19, 2004
    4,091
    71
    Bracknell
    +86
    Will connecting and analogue out to amp with a 75 Ohm cable as apposed to a 50 Ohm cable make any difference to anything?
  2. bobbypunk
    bobbypunk
    yes but no!
    Yes because it will be a different cable so will the sound may change, but no it won't give any specific advantage or cause any problems! AFAIK.
