Analog to DV converter
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Kirpal, Jan 16, 2003.
  1. Kirpal
    Kirpal
    I want to convert my old VHS/SVHS tapes to DV (digital video) format. Although I have tried to load these videos straight into my PC using ATI AIW 8500 card, I am not with the quality.
    Please advise alternative methods
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,330
    Rainham Essex
    +2,431
    To get old analogue video onto your PC (and asuming you have a DV input on your PC) you need an AV/DV converter. These can be bought from www.keene.co.uk and others.
    Be warned though, they cost around £250 :eek:
    Mark.
  3. jonna
    jonna
    Mar 25, 2002
    3,124
    Cheshire
    +2,210
    I have just converted my old family camcorder tapes (1991 upwards) straight from my camcorder (audio/video) into a Dazzle -Hollywood DV- Bridge, audio/video in (firewire out or audio/video out),which converts analog into dv.Bought it from pc world - £150 and used with ulead video studio 6 to capture it, it gave brilliant results.There is a newer version which uses usb into your pc.
    Good luck whatever you try.
    Jonna .
  4. dnrc
    dnrc
    Dec 23, 2002
    307
    16
    Near Norwich
    Look into the Canopus ADVC-100 and ADVC-50. These are supposed to be the nuts when it comes to analod to DV conversion. The 100 is an external box which is bi-directional, the 50 is a pci/front mount card which i think is one directional.
    If i remember the 100 is about £250, and the 50 is about £170.
    Maybe less though on e-bay.
  5. onzey
    onzey
    Kirpal
    Have you tried using your Panasonic NV-DS38 to do analogue to digital conversion and does it give the audio dropout problem doing this too? If you've not tried see page 41 of camera manual under heading Analogue-Digital Conversion. I never got round to doing this. ( my camera's still at Panasonic.)
    Richard
