Analog to Digital Conversion Fails
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by frankatlarge, Jan 24, 2005.
  1. frankatlarge
    frankatlarge
    I'm trying to help a friend convert some old VHS tapes to DVD. We're using a VHS player plugged into a Canon Pal MV550i camera which has an A-D mode, connected by Firewire (4 pin to 4 pin) to a Dell Dimension 8600 laptop.
    I can capture about 2 seconds (or less) of footage before the a-d process in the camera fails. I'm getting footage from the VHS player displayed on the LCD camcorder screen, until I start a capture program (both Roxio Easy Creator and Windows Movie Editor) - this seems to cause the conversion process to crash?
    Anybody got any thoughts???
    Frank
  2. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    Just a thought.
    Invariably, when you start the capture process, the program will start the play function on the camcorder as it is assuming that you want to capture from a tape on the device. Obviously, in this case, you don't want this to happen. There should be a function within these programs that turns off the tape control. Also, you need to make sure that the camcorder doesn't go into standbye mode whilst the VHS is playing.
    If you still have problems, it might be easier to just record directly onto a camcorder tape, and then capture the footage from there, onto the PC.
    Hope this helps.
  3. frankatlarge
    frankatlarge
    This sounds logical - I will give it a try on Thursday when I go back to my friends.
    I can always record from VHS to DV tape and then do the capture. Excuse my ignorance, but is it correct to say that this won't cause any extra picture degeneration because the transfer from DV tape to computer is digital?
    Frank
  4. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
    Yes you're correct. Once you've captured onto DV Tape, the transfer to computer will be lossless.
  5. TonyM19
    TonyM19
    Feb 28, 2004
    72
    Do DV tapes 'wear out'? Is there a reasonable number of times that you could expect to be able to use a DV tape to transfer analogue to digital?
  6. thebrummy_one
    thebrummy_one
    Feb 9, 2004
    372
    East London
    +7
    I don't know if the cannon is the same as my Sony but, I had to turn the 'AV in DV out' function on, on the camera before I could capture using the cam as a 'convertor'. it then happily captured the video.
    Another thing that comes to mind, are you trying to capture pre-recorded VHS tapes? if so, there may be some involvement of macrovision. This, I believe is a form of copywrite protection.
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,357
    Rainham Essex
    +2,442
    Yes, DV tapes are in contact wth the heads of the cam and therefore will wear out & get dirty and transfer that dirt onto the heads.
    At only £2.60 for a Sony Excellence DV tape I see no reason to ever reuse a DV tape. I keep all my origional footage and even copy the full edit back to a new DV tape once finished, in case I need to make further copies in the future.
    If you do want to reuse the DV tapes then I would say no more than 6 times, and I wouldn't even recommend that many. But the choice is yours.
    Mark.
  8. frankatlarge
    frankatlarge
    Yes,
    There are settings that you need to turn on the camera to do the a-d conversion, however I'm pretty sure we had them all correct.
    The tapes where originals recorded on a VHS camera, so I'm hoping macro-vision isn't an issue.
