Hi All,
I am a newbie at all of this but I think I have come up with an innovative setup.
I have my boiler, a deep freeze and other equipment on one side of my basements.
I figured out what I think is a clever solution to maximise screen size while still retaining access to them.
I will mount the 124" 2.4:1 screen on a plywood frame and hang the frame from chains in the ceiling. It will then fold up into the ceiling by pressing a button which will cause straps connected from the ceiling to the bottom of the screen using this solution:
https://garagesmart.com/collections/all/products/universal-xl-hd
I think if I get an acoustically transparent screen, I can mount my front speakers and sub woofer to the frame and back of the screen and have them lift up to the ceiling as well.
I would appreciate thoughts on the set-up as well as whether the speakers I have cobbled together should work, or if the quality is inconsistent and I should upgrade or downgrade some of them.
Here is a floor plan in 2d and 3d
Floor plans and interior design - Planner 5D
Projector: Epson HC 5050UB
Epson Home Cinema 5050UB - Audio General Inc.
Placed on a shelf just below the ceiling
Screen:
Silver Ticket 124" 2.4:1 acoustically transparent screen
S7-239127-WVS Silver Ticket Products Thin Bezel, 127" Diagonal, 2.39:1 Anamorphic Widescreen Format, 4K Ultra HD Ready, HDTV (6 Piece Fixed Frame) Projector Screen, WVS Woven Acoustic Material With Black Backing
Throw distance: 170"-190"
7.1 sound systems set up like this:
Best Speaker Placement with your Couch Against The Wall | BoomSpeaker
AV Receiver:
Yamaha RX-V6A 7.2-Channel Network A/V Receiver with MusicCast
should work with Dolby Atmos through the Yamaha Presence Speaker system
Speakers:
Subwoofer behind acoustically transparent screen: The Speedwoofer 10S Subwoofer MKII - RSL Speakers
Center speakers behind acoustically transparent screen: S35 Signature Center Channel Speaker | Polk Audio™
Left and Right Surround Speakers, on wall next to couch:
On-wall Speakers, Wall Mounted Speakers - Crutchfield
Same model to be used for rear speakers on wall behind couch
Overhead speakers for Dolby Atmos / Yamaha Presence, mounted above the couch
Polk Audio 70-RT
Screen:
AV Receiver:
Speakers:
Polk Audio 70-RT
