An electrical challenge...
Discussion in 'Home Cinema Buying & Building' started by rileyc03, Dec 19, 2006.
  1. rileyc03
    rileyc03
    Dec 19, 2006
    4
    3
    I am in search of an LCD projector - one that I can link a DVD player or laptop to... the issue is that I will be using the unit on Guyana in South Africa... Therefore it needs to be reliable and function at quite a high natural temperature (over 40C)...
    Most of the units I am looking at give a lower temp range (ie 0-35C)
    I am not to concerned about warranty as I will be back in the UK regularly so can get that sorted...
    Any suggestions
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,281
    Manchester
    +763
    Why not see if you can check which models are sold over there and, if necessary, contact appropriate maufacturers to see if they make a "tropicalised" version (possibly has a bigger fan).
    Chris Muriel, Manchester
  3. SeanT
    SeanT
    Jan 28, 2005
    6,156
    Coventry
    +368
    Get a bigger older one, some sort of conference series projector from the big manufacturers, tend to run nice and cool and last forever :)
