An easy one!
Discussion in 'Blu-ray & DVD Players & Recorders' started by R.G, Dec 5, 2003.
  1. R.G
    R.G
    Is the Sony DRU-530A DVD+/-RW Internal compatible with Windows ME OS.
    :confused:
  2. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    Why should it not be ?
  3. R.G
    R.G
    I had heard that it may only be compatible with 2000 onwards?
  4. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    Oh well I don't know much about this model. Bit pricey though £175 from dabs :-(
    Why do want this one ? Many are so much cheaper now
  5. R.G
    R.G
    What do you recommend?
    I was attracted to it because its a Sony, its new and the write speeds look to be beyond anything else.
  6. RecordablDVDfan
    RecordablDVDfan
    Aug 13, 2003
    2,902
    68
    +49
    I did'nt look too closely at the specs, see what you mean!
    I got the tri-format LG 4040B a few weeks ago. More than happy with it. Now only £97 from ebuyer http://***********/rpo1
  7. MarkE19
    MarkE19
    Aug 10, 2002
    17,355
    Rainham Essex
    +2,441
    Just had a look at it on the Sony web site and is listed as follows:
    Platform support: Windows® 2000, Windows® XP Home edition, Windows® XP professional
    Windows ME is not listed as being supported! Might be worth giving their tech support a call to find out for sure.
    Mark.
